Oil.
Jul 29, 2013 11:28:43 GMT 1
Post by transitmanred on Jul 29, 2013 11:28:43 GMT 1
What engine oil should I be using. What should I be doing to stop the rust, paint it with a product to neutralize the rust , then fill with filler ?
Oil.
Jul 29, 2013 12:17:41 GMT 1
Post by dodgerover on Jul 29, 2013 12:17:41 GMT 1
The only real way to get rid of the rust is to cut it out and weld in new metal. However if its just surface rust then sanding/ grinding as much off as possible then treating as above will work for a while.
Oil.
Jul 29, 2013 17:47:28 GMT 1
Post by muttleymk2 on Jul 29, 2013 17:47:28 GMT 1
Good old 20/50 oil for yer Pinto
