Post by chewie on Sept 13, 2013 14:44:57 GMT 1
hi I have been offered a 5 speed gearbox it's an mt75 comes with mount etc anyone know if it's an easy fit or is it a bit involved
Post by bobdragon12 on Sept 13, 2013 19:18:04 GMT 1
It's an easy fit but you need will need a suitable prop and the crossmember will need modifying.
Post by FredTransit on Sept 13, 2013 19:37:00 GMT 1
you will need
gearbox MT75 crossmember front prop section as its bolt up to the box
if fitting up to a pinto you need an adapter plate, it bolts directly to the DI.
You also need to cut a new hole in the floor to the right of the original, as the gear lever comes through the floor in a different place.
Its well worth a bit of effort.
Post by chewie on Sept 18, 2013 0:17:49 GMT 1
Great thanks for the advice it's in the post should be in the workshop tomorrow ready for the winter mods :-)
Post by bambimk1 on Sept 18, 2013 9:20:10 GMT 1
Heard you the first time chewie ::)A mk 3 mt75 crossmember will do I have one but muttley may have one as he will be closer
Post by chewie on Sept 24, 2013 11:12:10 GMT 1
No idea why my phone posts everything the Times sorry.... I think we are going to bin the pinto and go for a diesel this winter what's the difference between a di and a banana manifold engine?
Post by bobdragon12 on Sept 24, 2013 12:28:07 GMT 1
Don't quote me but I believe it is just the manifold , I'm going to ditch my pinto as well this winter and fit the DI . May even slap a turbo on it as from what I have read that's an easy conversion
Post by chewie on Sept 24, 2013 13:35:10 GMT 1
thanks Bob do they both fit? or is one more suited also anyone know if they run on veg oil
Post by bobdragon12 on Sept 24, 2013 17:20:17 GMT 1
Both fit , you need the Bosch manual pump to run on veg oil
