Post by bobdragon12 on Sept 24, 2013 18:25:33 GMT 1
Has anybody got a picture of the Bosch pump with the thingy removed ( can't remember what it's called)
Post by dodgerover on Sept 24, 2013 19:51:02 GMT 1
PATS? Boost actuator? Stop Solenoid? Big whatsit?
Post by bobdragon12 on Sept 24, 2013 20:39:43 GMT 1
Pats
tombrown1
tax n on the road after 18 year!!!!!
Post by tombrown1 on Sept 26, 2013 16:00:49 GMT 1
just take it off eventually you get down to the one wire livestop
Post by bobdragon12 on Sept 26, 2013 18:41:02 GMT 1
So,basically remove the plastic thingy with the multi block and under there somewhere is the solenoid . Many thanks
tombrown1
Post by tombrown1 on Sept 28, 2013 5:43:35 GMT 1
just remember that this is only a 6vault feed so a fat wire to the battery is only a quick temp fix you should here the stop click in as soon as it has life a wire through a fuse works fine
Post by bobdragon12 on Sept 28, 2013 9:09:06 GMT 1
Would I be better to put the ballast resistor back on to drop to 6v ?
