Post by orionsbelt on Oct 15, 2013 8:49:49 GMT 1
Hello, does anyone know if you can change a diesel bull nose over to a petrol grille on a mk1 transit. I've been advised the petrol engine still won't fit in?
Any help would be appreciated:0)
Post by FredTransit on Oct 15, 2013 10:45:48 GMT 1
which petrol engine? The V4 is sn option engine so will defo fit. The pinto can be fitted too with firewall mods
Post by muttleymk2 on Oct 15, 2013 16:53:07 GMT 1
What engine is in the van? If its a diesel or a Pinto then the flat front wont fit. You can fit a pinto and use the flat front but you need modded engine and gearbox mounts and a shorter propsahft.
Post by orionsbelt on Oct 15, 2013 21:41:35 GMT 1
It's got a 3 ltr petrol Capri laser in it at the moment. I like the bull, but would much prefer the flat. Thanks for your help with this, much appreciated :0)
Post by muttleymk2 on Oct 15, 2013 22:47:35 GMT 1
Do you mean 3.0 v6? The Capri Laser was a 2.0 or 1.6 Pinto 4 cyl
Post by orionsbelt on Oct 16, 2013 18:10:10 GMT 1
Hiya, it's a 3.0 v6 that's been rebuilt. Been told I could put a v4 .
Post by FredTransit on Oct 16, 2013 18:22:36 GMT 1
so are you taking the V6 essex out? As l said the V4 essex is a standard engine so will fit. The essex V6 was fitted with the bullnose so you will struggle with the flat front. May be dooable though. Remember the essex comes in V4 and V6 flavours.....
Post by comet on Oct 28, 2013 16:39:13 GMT 1
got a pinto in mine, all thats needed is to remove fan off engine and fit electric one in front of rad,mounts and prop dont need to be altered.
