Post by chewie on Nov 10, 2013 11:57:00 GMT 1
Hi I have been offered a good mk2 diesel engine as the pinto is still not in the best of shape in our camper will this engine mate to my original gearbox or the mt75 I have sitting in the workshop is there anything else I'll need?
Post by FredTransit on Nov 10, 2013 13:47:55 GMT 1
if you use the original gearbox you need the diesel bell housing. The MK75 is a better bet but you need the crossmember and front prop section to go with it. Also a new hole in the floor as the gear lever comes out slightly to the right of the original
