Post by ukmole on Nov 19, 2013 19:59:50 GMT 1
I have the original auto-choke carb, but with a manual conversion. I'm not sure that either work that well, as it starts immediately and also runs on when switched off. I'm sure it's running very rich. Any suggestions on an upgrade?
Post by bobdragon12 on Nov 19, 2013 21:15:26 GMT 1
I have a weber 34ich manual choke . Works well
Post by muttleymk2 on Nov 20, 2013 1:39:49 GMT 1
Seconded
Post by FredTransit on Nov 20, 2013 11:18:46 GMT 1
how far are you from Ohio? I could put you in touch with my mate Norm who specialises in uk spec capris. Do a search for Team Blitz Capris
Post by dodgerover on Nov 20, 2013 15:19:54 GMT 1
Is there a trick to cold starts with the VV carb, still getting used to mine, I can remember pump once then pull choke out on something Ford but no idea what, mines got a manual choke too.
Post by FredTransit on Nov 20, 2013 18:31:23 GMT 1
Post by fortyeight on Nov 20, 2013 19:02:32 GMT 1
i have the oridgenal vv on mine works spot on a little choke to start with and thats it it dose not like choke very much
Post by muttleymk2 on Nov 20, 2013 20:43:32 GMT 1
Is there a trick to cold starts with the VV carb, still getting used to mine, I can remember pump once then pull choke out on something Ford but no idea what, mines got a manual choke too. NEVER touch the throttle before starting with a VV, just pull the choke out
