Post by bobdragon12 on Nov 22, 2013 21:33:53 GMT 1
I have to admit this is a bit of a lazy post but it's probably quicker to ask than to drag out the haynes manual . Going to finish pluming in the DI tomorrow and have to wire the alternator which has 2 wire One has to be the battery light the other must charge the battery, does anyone know which is which . Also the pinto starter has 3 wires 1 to bat 1 is ignition and a 3rd . The DI only has on 2 connectors . Does anyone know what the 3rd on the pinto starter does? Thanks in advance jon
Wiring
Nov 23, 2013 0:13:00 GMT 1
Post by muttleymk2 on Nov 23, 2013 0:13:00 GMT 1
3rd term on starter is feed to coil on ballasted ignition, do u have a bolted or push on type alt connection?
Post by bobdragon12 on Nov 23, 2013 0:18:11 GMT 1
The DI is push on
Wiring
Nov 23, 2013 10:32:10 GMT 1
Post by dodgerover on Nov 23, 2013 10:32:10 GMT 1
I would think the charging wire on the alternator should be the thickest one, the warning light only draws a couple of amps at most so can be quite thin wire
Wiring
Nov 23, 2013 23:22:30 GMT 1
Post by muttleymk2 on Nov 23, 2013 23:22:30 GMT 1
Alt wiring terminals should be different sizes too.
