Post by bobdragon12 on Nov 23, 2013 11:13:30 GMT 1
Is there a reason the standard fan does not fit back on now the DI is in . Or is this normal and I just need to fit a electric one ?
Fan
Nov 23, 2013 16:01:18 GMT 1
via mobile
Post by FredTransit on Nov 23, 2013 16:01:18 GMT 1
is it hitting the crossmember? That will be cos its a Mk3 and its on the bottom pulley.
Post by bobdragon12 on Nov 23, 2013 16:24:16 GMT 1
Yep it is hitting the crossmember , I assume the answer is an electric fan ?
Fan
Nov 23, 2013 19:03:59 GMT 1
Post by FredTransit on Nov 23, 2013 19:03:59 GMT 1
You can actually cut the finds down and not have the engine suffer! Otherwise you need a different pulley and belts so it can be bolted to the water pump.
Post by bobdragon12 on Nov 23, 2013 20:09:28 GMT 1
It's strange close the engine is out of a T reg . The only other problem I have found is a small clearance issues between the inlet manifold and the brake servo as it's LHD
Fan
Nov 23, 2013 23:17:04 GMT 1
Post by muttleymk2 on Nov 23, 2013 23:17:04 GMT 1
If you fit a MK2 Di water pump (York is the same) u can fit the fan on it and clear the crossmember
Fan
Nov 24, 2013 16:51:43 GMT 1
Post by bambimk1 on Nov 24, 2013 16:51:43 GMT 1
If you fit a MK2 Di water pump (York is the same) u can fit the fan on it and clear the crossmember Sorry muttley pumps are different di dosent have bypass hose if I remember correctly.
Post by bobdragon12 on Nov 24, 2013 18:20:59 GMT 1
It's all good , I have a Mondeo sat waiting to break as the zetecs going into my cortina and the radiator has the inlets at the right orientation and a electric fans so I'm going to try and fit that
Fan
Nov 24, 2013 23:20:17 GMT 1
Post by muttleymk2 on Nov 24, 2013 23:20:17 GMT 1
If you fit a MK2 Di water pump (York is the same) u can fit the fan on it and clear the crossmember Sorry muttley pumps are different di dosent have bypass hose if I remember correctly. That's what I did on my Mk2, I blanked off the bypass and used a Mk3 header tank, hoses and thermostat housing
