Post by harry2012 on Aug 30, 2015 14:29:43 GMT 1
Personally I'm not interested in fitting an MT75 as I don't want to cut holes in the floor or the mat.
Post by jonochap on Aug 30, 2015 15:04:07 GMT 1
Went through 2 type 9's, both within about 50 miles of install. Right oil is an absolute must. Had a 4 speed hd for a while now, much happier van even though a bit slower. Saving for an overdrive setup
Post by sidewaysjas on Aug 30, 2015 15:05:55 GMT 1
Thanks for the info' guys it really helps. I'm running a 2.5Di which probably doesn't rev so freely as the 2.0 pinto. Overdrive with 4.63 I think is the way to go for me. I will keep trying to find an axle and look into the later ring and pinion option. Will keep you posted! Jas
Post by dodgerover on Aug 30, 2015 15:08:26 GMT 1
Personally I'm not interested in fitting an MT75 as I don't want to cut holes in the floor or the mat. But sidewaysjas (who's thread this is) obviously isn't as he was going to put it on 16's to get a few more mph, his options are to fit a different diff, bigger wheels or change the box, a standard MT75 is the same overall ratio more or less as his o/d box but if you can build yourself one with the 0.76 5th gear then he should gain a little more speed.
Post by sidewaysjas on Aug 30, 2015 15:25:10 GMT 1
Thanks harry2012 thats a really useful thread. I don't know anything about rebuilding diff's, but I night have to learn. If I can't get an axle thats definately an option. Jas
Post by southhem on Sept 7, 2015 12:35:49 GMT 1
Hi All, Re the gearbox /overdrive/4:63 diff solutions for the twin wheeler my experience is that the 2.0 petrol ( pinto or V4 ) engine is not man enough to pull that gearing if overdrive ( or 5 speed box) is utilised with 4:63. 3.0l V6 is fine of course but I'm not sure about the diesel derivatives. I would have thought they are underpowered for this combo too. So if you have a 2.0l engine choose overdrive or 4:63..... Not both.
Post by bambimk1 on Sept 8, 2015 0:51:15 GMT 1
Hi All, Re the gearbox /overdrive/4:63 diff solutions for the twin wheeler my experience is that the 2.0 petrol ( pinto or V4 ) engine is not man enough to pull that gearing if overdrive ( or 5 speed box) is utilised with 4:63. 3.0l V6 is fine of course but I'm not sure about the diesel derivatives. I would have thought they are underpowered for this combo too. So if you have a 2.0l engine choose overdrive or 4:63..... Not both. Totally agree.Mk2 came with 4.63 but mk 3 overdrive and 5 speed reverted to 5.14 as if like me you fitted a 4.63 to a mk 3 it ended up slower as it couldn't pull the taller gearing.
